跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
My GPS Antenna is not working, and I cant find a DIY fix.
I have an iPhone 6 that is having cellular antenna issues. Everything I look into is how to replace the wifi antenna and that is not what I am trying to do. Does anyone know a way to fix this? The phone will not connect to GPS and the Fit bit I got my sister for Christmas will not connect to the phone because of it. HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
"Weak or lost wireless connections
You have trouble connecting to a wireless network.
Dirty antenna grounds
If your iPhone has been disassembled before, it's possible that finger oils were left on the grounding locations for the Wi-Fi or Bluetooth antennas. These oils will cause grounding issues for the antennas, which could lead to a weak signal or no connectivity at all. Be sure to clean all grounding points with an electronics cleaning solution before reassembling your iPhone to prevent grounding issues." iPhone 6 Troubleshooting
iPhone 6天线柔性电缆更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
leftymckee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 943
