跳转到主内容
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP.
107 个问题 查看全部
Will not turn on, Just vibrates when on charge and has new battery
Hey guys i have a samsung j1 i left it at home one night and when i came home it was flat i tried to turn it on it didnt turn on so i put it on charge and it just vibrates every 5-10 seconds continuously and i have replaced the battery and it still just vibrates on charge and whrn you try turn it on it vibrates to let you know it has switched on but then nothing happens and i need pictures and data off the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
6条评论:
@telfz0r Is it still being recognized by your computer when plugged in? this sounds like a display issue since that is what could make it vibrate.
完成的
HEY i have the exact same problem no visuals on the screen just the rythmic buzz every 5 seconds letting you know that your lifes a failure and nothing will ever be right again. If you solve this problem please let me know :)
完成的
Anybody find a fix ?
完成的
fml :( buzz buzz
完成的
mines is doing the same thing
完成的
显示更多的1条评论
添加一条评论
4个答案
Option one: Try a new charger.
Option 2: Go to a service center and replace the charging panel
这个答案有帮助吗?
得分 0
3条评论:
Sometimes when a charger is in the same position for a while, this happens. It will only charge in a specific position, which explains the continuous vibration. It is simply charging in one position, then not charging when you move it even slightly. You need a new charger.
完成的
No its not the charger I have tried 5-10 different combinations of power connections and USB cords
完成的
Mmm...I'll keep that in mind.
完成的
添加一条评论
try replacing the screen
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
This might be because of 2 reasons
  1. You may be decided to turn on a phone whoch was switched off for like months or weeks.
  2. If you have new battery issues or battery replacements
So you may try charging using a high power adapter and the original working cable. Along with this try cleaning your phone charging port using toothbrush (with petrol drops if required)
这个答案有帮助吗?
得分 0
添加一条评论
What if the phone had got in contact with water and then it starts vibrating without turning on or showing that it's charging after 3-4 days of drying off?
这个答案有帮助吗?
得分 0
1条评论:
It's a Samsung J7 pro
完成的
添加一条评论
添加你的答案
Jake Walters 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 63
过去 30 天: 280
总计 15,334
