跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 个问题 查看全部
wont turn on or charge after dropped
My phone wont turn on anymore. I already did the hold home volume up and power button. Still doesnt turn on. Try to charge it but the phone still doesnt turn on and it keeps overheat when i left it charge it.. Then i try to investigate i removed the back cover of the phone then i saw my battery's connector to the motherboard is cut off. Kindly see the image link below. My question is it possible to fix this or do i need to buy a new battery? I think this is the one cause of the problem not 100% sure
https://imgur.com/a/8fWpk image 1
https://imgur.com/a/aAKxR image 2
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
It's almost impossible to re-solder the battery ribbon connector, unless you have very good micro-soldering skills and are willing to put up with the risk of causing a fire while working with the hot soldering iron near the battery. Try replacing the battery, as you said, that should be a good place to start from.
这个答案有帮助吗?
得分 2
3条评论:
Okay thank you. Later ill buy a new battery and check if the issue still persist
完成的
and one more thing. after i remove the back cover. There is a white thing like stickers on both sides. and i just cut them off. is this important on the phone? should i buy a new cover too? sorry not really familiar with this. so that i im not going back and forth.
https://imgur.com/a/HKsyG
完成的
Hi!
If the white things you cut trough are sticky to the touch they may need to be replaced, other than that no. I can't remember if the Galaxy Note5 was waterproof or not, but after this repair it won't be any more. Just keep that in mind.
完成的
添加一条评论
添加你的答案
Jomai Masangkay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 2,733
