跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s battery smell
When I was replacing the battery of my iPhone 6s the adhesive strips broke. So as the ifixit guide suggests I tried to use dental floss along with the tools in the kit to pry it out. I thought I almost had it when I started smelling something coming from the battery, at this point I stopped immediately and placed it in the other room. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
Either get someone to remove the battery for you or you will have to end up prying it out.
这个答案有帮助吗?
得分 3
1条评论:
Or just take it outside?
完成的
添加一条评论
Hi
Sorry to ask did u disconnect battery from motherhood.
If not disconnect battery first.
Remove Lcd from phone.
Now take some plastic card like playing card and put it under battery from left side of phone and slide it slow under the battery. And don’t use any metal thing to take out battery.
In this way u can remove battery safely.
Always use safety gears.
If still not confident better to go to some repair store.
Regards
Phone beats
这个答案有帮助吗?
得分 2
6条评论:
Yes everything's removed and disconnected
完成的
I am mostly concerned about the smell
完成的
I think smell is due to when to cut outer black layer of battery.
Don’t try to take battery with any metal thing. Remove it with plastic playing card.
Again if you really not confident better to go to repair store.
Regards
完成的
Please keep spam out of your answers. You can advertise phone beats in your profile page.
完成的
@captainsnowball this one too:
What does it cost to replace the glass?
完成的
显示更多的1条评论
添加一条评论
Lol when I read the question I was like 'Wait why are you smelling the battery?' XD
Anyway, the battery might be corroded or leaking.
这个答案有帮助吗?
得分 0
4条评论:
Honnestly had the saaaame issue and got scared quick cuz you always here about batteries exploading so when i started smelling a sweet toxic smell i just immedietly pried it out to avoid ruining the phone and it worked. Now im about to install the new battery
完成的
Lol...At least you got it taken care of.
完成的
Haha yeah about that, i apparently ordered a ifixit iphone 6 tool kit battery replacement.... I have an iphone 6S soooo when i was trying to install the battery to my surprise wouldnt fit, because iphone 6 and 6s are not compatible, huge blow i needed my iphone this week and now Iphone6S batteries are out of stock, if you happen to know how to help before tomorrow 15:00pm EST id be glad to order another online.
完成的
I dont...Sorry
完成的
添加一条评论
use a hot air in the back of the iphone (not very hot) the glue under the battery will be more elastic and you can remove it without problem
这个答案有帮助吗?
得分 0
1条评论:
60°C / 140°F to be clear. 80C is okay too if it's not hot enough depending on how hot it is in your area.
完成的
添加一条评论
Probably your battery has a small hole . But I recommend to change your battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Trey johnston 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,504
