跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
iPad Air 2 - 11.2.5 update results in error 56
I tried to update my perfectly fine iPad Air 2 to 11.2.5 and now I have an expensive paper weight. Error 56
Tried with 2 computers but still same problem , the problem is not with ipsw or my laptops, please help m what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
• Download the iPSW directly.
http://www.iclarified.com/8500/where-to-...
Put the iPad in to DFU mode.
https://www.imore.com/how-to-iphone-ipad...
Use 3Utools to flash instead of iTunes.
https://www.3u.com
这个答案有帮助吗?
得分 0
添加一条评论
I Fix it...
First find a Neodimio magnet pieces (2)
next...let to Ipad finish the battery.
Put a pair of neodimio magnets behind the turn on botton (uper)
Put the cable (usb) in the plug of Ipad
Put the other extreme in your Mac
(recomended is USE Apple Configurator program)
Use Itunes normally
That's all...Your Ipad will RUN Like a NEW
Then you can go to your appl store and change for one better.
It's really works
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem with my ipad air 2(wifi).
Yesterday i couldnt do the update wifi,so i did with itunes.... And showed up the error 56....
Could you fix it???
I didnt want a expensive paperweight...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amin Rezayee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 759
