跳转到主内容
A white Compact refrigerator with separate freezer and refrigerator compartments.
11 个问题 查看全部
Freezer is cold, refrigerator not cooling
I have an older model Kitchenaid Superba and the refrigerator has stopped cooling. The baffle door closes and won't reopen. I can open it manually, but when the refrigerator gets cool it closes and doesn't reopen. At first, we were told it was the motherboard so we had it repaired, now we're being told the compressor may be going bad. All the lights wok, the ice maker works, the dispenser works, the freezer is at 0, the compressor runs but the damper baffle does not reopen once it closes, evaporator fan is operating, fan behind fridge is working
Thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Our model number is KRFC300ESS01. Freezer is working. Refrigerator is not.
完成的
添加一条评论
3个答案
最有帮助的答案
I doubt it’s the compressor. Do you notice ice around the damper? Or frost any where, including the freezer? Check the back wall of freezer for frost. Without a model number I can’t be positive, but I’m sure that damper operates off the temperature thermostat for fresh food section. It has to be an air flow problem somewhere. If it’s not defrosting properly the evaporator coils could be iced up. If you see frost in freezer in plug the refrigerator and remove the freezer shelves so you ca remove the panel on back wall to expose the evaporator. If there if frost on the evaporator coil take a pic. Notice if the coils are covered evenly with frost or if it’s only ona certain section. That’s all I have without a model number. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Replace the baffle door. It's hard to open because colder air condenses and lowers the air pressure. Meanwhile the outside ambient air is higher pressured, Thus when opening the door you have to overcome the differences in air pressure. At least your door seals are in good shape.
这个答案有帮助吗?
得分 1
1条评论:
I forgot to mention, I've replaced the baffle assembly and the refrigerator thermistor
完成的
添加一条评论
Ours ended up being an issue with the mother board. I took the mother board out and sent it to The Repair Shack to be repaired. I found them on Ebay when I was looking for a new mother board. Problem solved!
这个答案有帮助吗?
得分 0
2条评论:
Yes! Good for you. I hope the repair wasnt expensive and hopefully your last repair for a long time.
完成的
Like this solution !
完成的
添加一条评论
添加你的答案
Chad Odell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 27
总计 8,850
