I am looking for an SSD compatable with my grandfathers MBP
Hello there! I am currently looking for an SSD that is compatible with an Early 2011 15" inch MBP and is within a budget of $120.
Any help would be greatly appreciated !
You can use any kind of ssd you can find as long as it uses the SATA I, SATA II, or SATA III compatible connection interface. So to answer your question yes, a Samsung 850, or 860 EVO or pro ssd will work!
这个答案有帮助吗?
Here ya go! Toshiba 2.5" 512 GB SSD. Better hurry! last one!
And here's the guide to put it in 2011早期 15寸 MacBook Pro 一体化机硬盘更换
这个答案有帮助吗?
oops... 120 dollars... 60 over...
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 93
3条评论
$120 is on the tight side... Most of the drives is this price range will be quite small 64/128 GB. Its worth getting the bigger drive Aiden found from IFIXIT.
由 Dan 完成的
Would an 850 EVO or 860 EVO work? they are both $100 on Amazon
由 Cole 完成的
I use Samsung 2.5" 850 EVO drives (the 860 is a lower end version). They are a good drive but the ones being sold on amazon are the smaller ones at this price. The smallest I would go with is a 256 GB.
由 Dan 完成的
