跳转到主内容
System doesn't recognize Samsung EVO SSD
I want to install a new drive in my MacBook Pro. I chose the Samsung EVO 250 GB.
To install I followed these steps:
  • Connecting the SSD with a SATA cable to my Mac. Using disk utility, erase the SSD. Clicked on GUID partition and MacOS extended (journaled).
  • With carbon copy cloner I cloned my old hard drive to the SSD, including the reboot option. I then installed the new SSD in my system,
But when I turn it on it only shows the white screen of death. When I start up with cmd+r and go to disk utility, the SSD does not show up.
What did i do wrong? I hope someone can help me out!
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I would recommend you stick with Sierra. High Sierra has some issues still with SATA based SSD's with the newer APFS High Sierra automatically upgrades the drive to.
完成的
添加一条评论
3个答案
已选择的解决方案
reformat the drive & install the system. The do not clone (destroys the repair partition). Use migration Assistant to move your user and apps.
这个答案有帮助吗?
得分 2
3条评论:
@mayer - Likely needs a new HD SATA cable too!
完成的
@danj absolutely , and the 2012 model cable.
完成的
Here's the details, follow this IFIXIT guide: MacBook Pro 13" Unibody Late 2011 Hard Drive Cable Replacement and this is the better cable: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. I also recommend placing some electrical tape on the uppercase where the cable rests as the aluminum abrades the cable
完成的
添加一条评论
@piera , I can almost guarantee that you either have a damaged SATA cable, or a defective Samsung SSD Drive.
I am running this config with High Sierra fine.
Also, there is no reason to use CCC to clone.
The built in migration wizard on a clean install will take care of anything.
The only thing you may need to do is re-enter installation keys for applications like MS Office.
这个答案有帮助吗?
得分 1
3条评论:
I would still stick with the older Sierra OS @avanteguarde I'm still running the beta releases and they are still having issues with queueing with the Finder process. Don't get wrong I do think the new file system is better! But not at the risk of not being able to save a file without needing to wait a good 30 sec. or more depending on what else I have running concurrently. Mac OS Extended (Journaled) doesn't have this issue.
完成的
@danj I am in no way disputing the OS. Just saying the drive works great! :-)
完成的
@avanteguarde - And I'm using a Samsung 850 EVO in my system too! ;-} Great Drive!
完成的
添加一条评论
I am also running the 500gb Samsung Evo SSD - after installing I had an identical issue. It was indeed the SATA cable. -- Went ahead and installed the new SATA cable, and the system works very well - and significantly better than it did with the old crappy HDD.
Also, I am running High Sierra and everything is fully operational.
Best of luck in fixing your issue brother!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Piera 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 4,910
