跳转到主内容
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 个问题 查看全部
USB device not recognised. Win 7 home premium.
I have an Ipad air LTE. was produced to me as DISABLED as they put the wrong password in too many times. The ipad charges through the port but is not recognised by windows so i can't do much to get into the device. Tried on several machines so it isn't computer related. Have not got another lead to try, but my ipad mini works fine connected to same computers, same lead. Any suggestions?
Sounds like an electronics repair job i *think*. Thoughts?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Have you installed iTunes? Have you tried different cables?
完成的
Yes i have, latest version and no i havn't. The mini works so it's not the cable
完成的
Cheers mate, yes it goes into recovery mode but as soon as it is plugged into the pc the USB message comes up saying it can't recognize the device, so that's where the world ends lol
完成的
@smythie17 Hello, does anything show up on iTunes when you plug it in?
完成的
no it does not
完成的
添加一条评论
2个答案
已选择的解决方案
Hi @smythie17 ,
Try forcing the iPad into the recovery mode and see if this works at all.
1. Turn off the iPad
2. Launch iTunes.
3. Plug the USB cable into the computer.
4. Press and hold the Home button down and plug the other end of the USB cable into the docking port.
Do not release the Home button until you see the picture of iTunes and plug
5. Release the Home button.
6. Hopefully iTunes has detected that the iPad is in the recovery mode.
7. Select Restore iPad
这个答案有帮助吗?
得分 2
添加一条评论
Go into Device Manager
See if you have any devices with error messages
Remove these from Device Manager
then scan for hardware changes.
这个答案有帮助吗?
得分 0
1条评论:
Did that as well, just comes up with same error message when connected
完成的
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 518
