跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
My iPod frozen after restore and won't go to disk mode
i tried to restore my ipod classic 20gb and after itunes finished downloading software it told me to disconnect my ipod and reconnect it with external charger i did it but it shows me a picture about a charger and it won't change i tried to restart it but every time i do it shows me an apple picture and goes back to the old picture and the pc doesn't read it with i tunes or explorer i tried to put it to disk mode but it wont let me and when i try to restart it when it is plugged it shows me a charging battery i didn't drop it i didn't get it wet so what is the problem ??????????
please help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
omarxboy, by the size of your hard-drive I would say you have a fourth gen iPod. If that is correct, it requires you to be plugged in to a firewire external charger to finish the restore process. Until you do that, it will not finish and won't be recognized by your software. so bottom line, you need to hook it up to external firewire to work. Good Luck.
这个答案有帮助吗?
得分 2
6条评论:
i did it but nothing happened at all and the same picture is showed (the charger) some guys told me it's a battery and some other said it's the software and i am confused now any way thanks alot for ur respond
完成的
omarxboy, so you had no change with the firewire? It has to be a firewire, not USB. If you have tried and it did not work have you tried to reset it already? Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Select(center button) buttons until the Apple logo appears. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button (center button) is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
完成的
yes i tried all of that and it didn't work
完成的
Just to make sure. You did use firewire?
完成的
yes i did but it did nothing
完成的
显示更多的1条评论
添加一条评论
Hi, I've got the exact same issue. tried all the above, but still receive the same symbol. When i repeat the steps it still reverts back from apple logo to the charger:
'Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Select(center button) buttons until the Apple logo appears. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button (center button) is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.'
Griff74 :-(
这个答案有帮助吗?
得分 0
1条评论:
Did you finish the restore with a FIREWIRE connection? It will not finish with a USB connection and will give you that error.
完成的
添加一条评论
Hello, I have the same problem. I plugged in an adapter charger for more than 48 hours but still nothing. I tried to reset it by pressing select and hold together, but the apple disappears, giving way again to the icon of the electrical outlet. I also tried to put it into disk mode but it does not work either.
这个答案有帮助吗?
得分 0
2条评论:
fleur 303 what ipod do you have? It is possible that you may require a new battery. Also make sure that your dock connector is clean, does not have any corrosion and has no bend pins.
完成的
It's a classic, 4th generation, 20 GB, special edition, refurbish. I also believe that this may be the battery, I'll go to an Apple store today to see how they feel about this situation. However, I don't understand is why the battery was working fine before the restoration and that it was after this action that it no longer works ..?!
完成的
添加一条评论
添加你的答案
omarxboy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 5,035
