跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Why is my iPhone 6s screen not responding?
HI, my friend accidently dropped her iphone 6s into the toilet bowl. She immediately tried putting it in rice to let the water drain out. After that, the phone turned on but the phone did not respond to touch. The screen looks fine and the home button and power button are working but when i touch the screen, there is no response. So, i was wondering is there a problem in the digitizer or logic board or anything else? Is there any way i can check what is wrong or would an lcd replacement help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The water probably damaged the digitizer. I would disassemble it (if you're tech inclined) and dry it out that way. Unfortunately rice doesn't do much to actually pull water out, or prevent corrosion from forming. If the device is turning on though, that's a good sign. You might just need a screen replacement (new Glass/LCD/Digitizer). I've had that fix very similar problems.
这个答案有帮助吗?
得分 1
添加一条评论
water damage is not fun. you may need to fully disassemble the phone based on how damaged it is.
iPhone 6s拆解
Electronics Water Damage
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Reenashini Rajendran 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 58
