跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
Galaxy s7 "custom binary blocked by cc mode"
Hi,
I installed cc mode.apk from samsung knox support page on my rooted device, now when i want to boot keep saying "custom binary blocked by cc mode", so i tried to flash a new rom, but in the download mode there is a warning that says "download mode is blocked by cc mode", now i dont know what to do.
PLZ HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
What model number is your device? You will need to reflash correct matching official Samsung Firmware to remove the custom binary that has been flashed onto the device.
Sounds like the device may have been rooted or had a custom kernel installed but OEM unlock was not left on enabled in developer options.
这个答案有帮助吗?
得分 2
7条评论:
My device is SM-G930F, and i cant flash because download mode says "DOWNLOAD MODE IS BLOCKED BY CC MODE", my device is rooted and twrp installed
完成的
Hold volume down + power + home (10-20 secs) until you get to the blue download prompt screen. You can flash there.
https://updato.com/firmware-archive-sele...
You can download the official Samsung firmware using the above link.
Flash with HOME_CSC and not CSC if you want to keep data without factory reset after flash.
完成的
i cant use download mode because is blocked by cc mode
完成的
There is no solution for this currently. I am curious if my Z3X flashing box can remove this lock because it does remove FRP lock without needing to reset the phone when it says custom binary blocked by FRP lock.
完成的
its not frp lock, is cc mode lock
完成的
显示更多的2条评论
添加一条评论
Boot into safe mode and try to uninstall cc mode apk.
这个答案有帮助吗?
得分 1
6条评论:
Here is a guide linked on how to boot safe mode: https://support.t-mobile.com/docs/DOC-28...
Hopefully this works.
完成的
I will try.
if works i will thank you so much
完成的
but my device directly shows custom binaery blocked by cc mode, the samsung logo does not shows up
完成的
I hope the solution I have the same problem is the custom dual boot problem blocked by lock frp SAMSANG S7 G930F
完成的
Please help with the solution custom binary boot blocked by frp lock
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Fabricio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 6,937
