跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
205 个问题 查看全部
No idea what is wrong with it?!
Son drop his 2ds (3 weeks old) blank black screen orange light at top on and blue light flashing, won’t start! Left it all night still the same did some research on YouTube ... to take battery out and put back in.... done that.... wouldn’t start.... left it on charge.... now no lights and nothing happening? Anyone got any ideas on how to fix this I have a very upset 5 year old and I can’t afford a new one! HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi!
If the console is 3 weeks old, you can try returning it for a warranty repair, if you still have the receipt. They will change it for free, as long as you tell them that it just stopped working (not that your son dropped it).
这个答案有帮助吗?
得分 1
7条评论:
But wouldn't that be lying? ಠ_ಠ
完成的
yes but, well... uhm. yes.
完成的
Lol just teasing you. But really, if they were to found out about what happened to it, you might get in trouble.
完成的
No, you wouldn't, they won't care, they'll just give him another console and throw the old one in the garbage.
完成的
Not with Gamestop (<- GRRRRRR >:( )
完成的
显示更多的2条评论
添加一条评论
I have this problem at the moment and also a few years ago. I haven't found a solution YET, but you may want to mess around with it a bit before taking extreme measures and getting a new one. If its in really bad shape, then you may need repairs though. :(
Update (01/31/2018)
Remember when I said I was fixing one? Well, if you are extremely careful, take the left shoulder button off and gently push the orange plastic things in a bit. The bottom screen will work if you try poking around this area carefully. As for the top screen, I didn't find a solution. DO NOT PULL THE PLASTIC THINGS OUT.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jess 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 262
