跳转到主内容
1.83 GHz Core Duo 处理器 或 1.83, 2, 或 2.16 GHz Core 2 Duo处理器 A1208 (EMC 2104/2110/2114/2124)
201 个问题 查看全部
What to do with circuit glued to hard drive when replacing drive
There is a circuit glued to the old hard drive that does not exist on the replacement hard drive. do I reglue to the new drive or discard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Of course it needs to be attached to the hard drive to monitor heat, but don't put tape in between the sensor and the drive. Place it on the hard drive so that it makes good contact and using electrical tape, tape it into place. Here's what I use: Electrical Tape in 6 Assorted Colors
Electrical Tape in 6 Assorted Colors图片
产品
$7.99
这个答案有帮助吗?
得分 2
添加一条评论
Tape should work fine on it. If it is not connected the fans will run constantly at high speed when the machine is on.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
craigl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 695
