跳转到主内容
加入维修社区 - 创建账户
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Riding mower won't start
Hi, My Craftsman model 917.250, Kohler 26 horse won't start.
I hop on, depress brake, turn key, engine turns over.
It has good spark at spark plug - removed plug, reattached plug wire, turned engine over with end of plug held near metal frame, sparks.
Checked fuel, also squirted starter fluid in carburetor, turned engine over, still won't fire.
Squirted starter fluid directly in cylinder - removed plug, squirted fluid in cylinder, replaced plug, turned engine over, no fire.
Checked for damaged flywheel key, okay too.
Scratching my head, puzzled, any ideas?"
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Scot Mckone if you have fuel and spark check your timing as well as your valves. You may not have compression
完成的
My craftsman riding lawn mower will not start wont even click on what could be the problem
完成的
My riding mower aslo wont fire done bought new plug new solenoid new fuse repaired wires also wont start only get a little click
完成的
添加一条评论
1个答案
try to bypass the ignition switch by puling it and closing the circuit manually
这个答案有帮助吗?
得分 0
5条评论:
If it is getting spark, how will over-riding ignition switch help?
完成的
It may not, but I like to remove as many things from the system as possible when troubleshooting.
完成的
The brake sensor may not be working too. It sound like you have been very thorough. Compression as mentioned by oldturkey may be your best bet.
完成的
Has compression. how do you check timing?
完成的
Scot, try using this previous thread as there seems to be a lot of similar issues...
Craftsman tractor engine compression or timing issue
完成的
添加一条评论
添加你的答案
Scot Mckone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 7,278
