跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
Replacement screen not sitting in on bottom right
This is probably a common issue for aftermarket screens.
Is there any particular reason why it happens? I tried two screens from different suppliers and the same issue occurs.
Also the iphone housing is in excellent condition, no bends or dints on frame.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Hey, if you check the flex on the screen that goes to the motherboard, there is a metal part on it. that part probebly hits the motherboard or anything else nerby.
see this picture:
https://d3nevzfk7ii3be.cloudfront.net/ig...
the flex should lay as this one does a little bit from the metal part on its right side and not to high up.
I have had this problem twice before and that helped.
这个答案有帮助吗?
得分 1
1条评论:
thanks so much that worked, i had to flatten it out because that rectangular brick slides out of place and it fits in a small rectangular hole and if they dont match the corner comes up
完成的
添加一条评论
Hi Ben
You are one of the great sages, but if it were not so, I would say:
Something similar happened to me once. I would say it has to do with the fasteners in the frame of the screen or the thickness (too thick) of the frame.
I have also seen chassis bent in strange ways, it is not necessary a blow, with enough pressure can affect.
Another screen or reinforce the adhesive on that part could help.
这个答案有帮助吗?
得分 1
添加一条评论
Hi there is a possibility that your iPhone's rear housing is bent it's a very common issue with the iPhone after been dropped on the corner or kept in tight Jeans so it may never fit properly. you can check by placing it against a flat surface (making sure the camera is not in the way) and check if there is any gaps between the surface and the phone if there is you have a bend, sadly a rear housing is such a pain in the arse to replace even apple just replace the whole unit for exchange price which dose vary if you go to a Apple Sore or Apple reseller i would not trust a corner shop with this job.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 1,020
