跳转到主内容
Repair and disassembly guides for Magnavox DVD players.
Why doesn't my DVD turn on
The power doesn't turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
@cherlimae what model is your DVD player? What have you checked?
完成的
mrb410b/f7 it will not power on
完成的
I can't get my dvd player to turn on
完成的
My magnavox dvd want player thedvd
完成的
What going wrong with it it say erro
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
While I'm not trying to be fresh, lets go through the motions...
1) Be sure that it is plugged into a known good outlet (test with a lamp for example)
2) Are there any lights on the unit at all? Usually there is a standby light (red) that glows when the unit is plugged in but off.
3) Does the red light mentioned in #2 go off but no other action?
Please update the posting with a response to the above and further assistance will follow.
In the worse case, the power supply portion of the player will require service which may cost around $50 or so with parts.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cheryl Cross 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 2,271
