跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
Can TouchID buttons be replaced without replacing the entire board?
Palmrests for these units are being sold without the TouchID / power button on the far right end of the touchbar.
The TouchID button has a small integrated flex/ribbon cable (labeled "00920-A") that then plugs into a secondary flex/ribbon that extends the original and changes its plug type so it can connect to the logic board under the headphone jack ribbon. That extender cable is labeled with "821-00645-A // MFC0517" and I've been able to find them for sale, but I can't find replacement TouchID sensor anywhere.
Powerbookmedic's listing for the palmrest claimed that the TouchID sensor is not included with the palmrest as they are "married to the logic board". Does that mean that if the TouchID sensor/button is damaged or if its cable is ripped, the ENTIRE LOGIC BOARD needs to be replaced?
Please, somebody, tell me that this isn't true.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Definitive answer:
You can use the original TouchID button with a new board, or a new TouchID button with the original board, but you'll lose the ability to use biometrics without having Apple do something with AST2, which independent repair shops do not have access to.
Some degree of onboard component swapping MAY be possible, but I have yet to experiment with that personally.
This and tons of other great information is available at https://logi.wiki !
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
PowerBookMedic is correct! An independent servicer or you can't fix this.
If the sensor is broken you'll need to bring your system into an Apple Store or ship to Apple for them to repair it. Apple is the only one that can fix this.
Think of it this way this is a deterrent for someone to steal your laptop as well as offer a level of privacy. Just like your iPhone or iPad the TouchID or FaceID protects you.
这个答案有帮助吗?
得分 2
3条评论:
Thanks so much, Dan! I really appreciate the confirmation and insight!
So, to dig just a little deeper: Does it appear that the sensor board actually has MEMORY that stores your prints?
If so this strategy would make sense - you wouldn't want someone getting your computer and swapping out the fingerprint sensor with one that authenticates with their print rather than yours. That'd certainly be a far-fetched situation in my opinion, as having literally just completed my first palmrest swap on one of these, I can confirm that it was quite the harrowing experience. I can't really imagine that theft-by-technician is THAT common... but if the sensor stores the biometrics then I get that there's a plausible defense to the design decision Apple made here.
If it's just a sensor , though, the thought that I'd have to buy a $1,000+ logic board because a 3mm wide flex cable attached to the frame with adhesive was ripped during removal seems like an incredibly disappointing cash grab by Apple.
Any idea?
完成的
You'll want to review the IFIXIT teardown: MacBook Pro 15" Touch Bar Teardown
Sorry guy time to put the system back together and bring it into Apple. I'm sure it's a lot cheaper that that!
完成的
Hah! Luckily I was just discussing hypotheticals.
I was able to remove both the sensor and the extension flex ribbon without any damage occuring, but it's super annoying that the stakes are so high with a piece that's so incredibly fragile and firmly adhered into such tight quarters within the palmrest's frame.
I asked for help here because I could tell that the removal would be a pain and the teardown didn't have any particularly helpful images when it came to the TouchID button in particular. I've since added some insight into the comments here: 配备Touch Bar的15英寸MacBook Pro拆解
完成的
添加一条评论
This is partly correct. You can replace the touch id sensor, but you will lose the ability to use the fingerprint. I think it depends on if you encrypted your disk if you might be able to just reinstall it, but I have not read that you cannot do it, just that fingerprint unlock is not possible.
There is a specific chip in it that binds it to the board.
With the right equipment you could perhaps transfer it, but that is high level skill - check out Rewa if you’re interested, they do that for some parts and have videos.
It's something I personally skip on - and on Apple products all together because of the horrors of repairing them.
If indeed the board does not work at all without the flex cable, then the cable has the chip on it.
Since I have seen these boards boot without it attached, I cannot imagine it will not work at all, but if that is the case, please be very specific in the how and why before you claim it. Thank you.
这个答案有帮助吗?
得分 1
1条评论:
Thanks so much for posting this!
You are absolutely correct, verified many times over: You can use the original TouchID button with a new board, or a new TouchID button with the original board, but you'll lose the ability to use biometrics without having Apple do something with AST2, which independent repair shops do not have access to.
Some degree of onboard component swapping MAY be possible, but I have yet to experiment with that.
完成的
添加一条评论
Have bought a TID button and installed it. But yes, you have to get Apple to do the AST2 thing.
这个答案有帮助吗?
得分 0
1条评论:
Apple did it for you? What was the price? I ripped my flexcable off too today, and now i want some replacement, as i got a like brand-new i9 with 64gb/4tb, without a powerbutton for now :-(
完成的
添加一条评论
添加你的答案
ed 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 44
过去 30 天: 200
总计 9,732
