跳转到主内容
寻找你电脑的维修方案。
21244 个问题 查看全部
Building computer in old gateway 2000 case
I have a old gateway 2000 case that’s has ATX motherboard screw holes. The pci card slots are in the right place. But the power supply is different but I think a SFX PSU will work. All I need to work on is the fixed IO shield. I’m not sure it’s worth trying to build a new computer in this case?
I’m not sure if this is a off topic question.
Here’s the case:
This I the IO shield:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
18条评论
you mean the IO shield? the metal thing over the motherboard connectors?
完成的
Ya. Didn’t know what to call it.
完成的
that is removable. hold on while I find instructions.
完成的
Well the one on this case isn’t removable. So I’m going to buy a Dremel to remove it and make it fit the new ones in.
完成的
can you post a photo?
完成的
显示更多的13条评论
添加一条评论
2个答案
最有帮助的答案
I Love Sleeper PC's I have seen people use older case's but as old as it makes me feel Id say this is old enough to be considered a Sleeper PC.
you may find yourself cutting metal and splicing cables for I/O but if you want something as a hobby build trust me people will look at this PC and wont expect it to be running the new hardware you have installed.
heres a video of a guys IBM sleeper good luck with your build.
https://www.youtube.com/watch?v=v-TkQ7KZ...
这个答案有帮助吗?
得分 2
2条评论:
Yep that’s exactly what I want it to be like. I think the case is 1998 but it still should fit all the new stuff in it.
完成的
funnily enough I own a working Gateway Performance 450 and it look nearly identical to this except the 450 has a much larger case. I don't think I could bring myself to part it out for a Sleeper build as I still have windows 98 on it with all my original games.
完成的
添加一条评论
I never knew how to remove it by I found this. it shows how, it also made me laugh. I was expecting him to use the screwdriver to pry it out or something. HIS IS BACKWARDS SO REMOVE FROM INSIDE THE CASE
-video by Carlos S. M. Computers-
这个答案有帮助吗?
得分 1
16条评论:
By the way I can’t see this video?
完成的
Hmm. what browser are you using?
完成的
Safari on my iPhone.
完成的
...no idea then. embeds don't work properly on iOS... maybe?
完成的
显示更多的11条评论
添加一条评论
添加你的答案
Padraic Hoselton 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,200
