Building computer in old gateway 2000 case
I have a old gateway 2000 case that’s has ATX motherboard screw holes. The pci card slots are in the right place. But the power supply is different but I think a SFX PSU will work. All I need to work on is the fixed IO shield. I’m not sure it’s worth trying to build a new computer in this case?
I’m not sure if this is a off topic question.
Here’s the case:
This I the IO shield:
18条评论
you mean the IO shield? the metal thing over the motherboard connectors?
由 Aiden 完成的
Ya. Didn’t know what to call it.
由 Padraic Hoselton 完成的
that is removable. hold on while I find instructions.
由 Aiden 完成的
Well the one on this case isn’t removable. So I’m going to buy a Dremel to remove it and make it fit the new ones in.
can you post a photo?
由 Aiden 完成的
显示更多的13条评论
