跳转到主内容
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 个问题 查看全部
Why has my trackpad started to behave erratically again?
ASUS model: X555LA-XX290H
Intel Core i3-4010U
Windows 10 Home 64-bit
When I first bought my laptop a couple of years ago I upgraded to Windows 10 a few days afterwards. The trackpad would never scroll properly from then on - there was a huge amount of input lag whenever I tried to scroll.
I mostly used a mouse, but after a year or so the trackpad started to work normally. There was one period of a few days where it stop scrolling again, but other than that it's been fine.
However, a couple of days ago it stopped scrolling properly again. The following day the cursor started jumping around simply from keeping my finger on the trackpad - without moving my finger at all.
I've got the most recent driver installed (which hasn't been updated for some time), repaired the program, reinstalled it and checked for viruses but nothing has worked.
When the program - ASUS Smart Gesture - was uninstalled (and before I reinstalled it), the trackpad was still behaving erratically.
Any help would be appreciated.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Possible swollen battery pressing on the underside of the trackpad.
这个答案有帮助吗?
得分 3
3条评论:
I run it off the mains most of the time and it's cool as a cucumber.
完成的
A swollen battery doesn't care about heat. Look at it.
完成的
lol fixed mine after unplugging the charger LOL
完成的
添加一条评论
添加你的答案
Bodhi Wolf 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,344
