跳转到主内容
13.3" flip-top, touchscreen laptop (SVF13NA1UL).
17 个问题 查看全部
Why does my Sony Vaio randomly turn off and need to be reset everyday?
My sony vaio flip randomly stops turning on once a day. The only way to turn it back on is by removing the internal battery and restarting it. Whats causing the shut downs and how do I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
I assume that the laptop is supposed to be continually on, is this correct?
Have you checked that the fan is running and that the exhaust vent is clear so that the laptop is not overheating?
If the fan vent is blocked, use a vacuum cleaner (using short bursts) to clear the vent. Do this with the laptop turned off so as to not damage the fan.
If the fan is not running then here is a link that shows how to open the laptop to access the fan
这个答案有帮助吗?
得分 1
4条评论:
Also, download Battery Eater to check the health of your battery.
完成的
My computer is off and in my backpack, it will turn on during some morning classes but then stops turning on (even if plugged in), till I get a chance to remove the battery and reset.
完成的
Hi,
What happens if you leave the battery out and try to run it straight from the adapter?
完成的
Hey,
I've never tried, but I will attempt it next time it shuts down.
完成的
添加一条评论
添加你的答案
Destiny Vail 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 4,027
