跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
iPhone 7 BB CPU itself shorted
Has anyone had any Iphone 7 BB CPU shorted yet? I have done several 4013 and -1 repairs on these and recently took in 2 phones from a shop in Florida where I had a short on BBPMU_TO_PMU_AMUX1 and PP_1V0_LDO9 on one phone and just PP_1V0_LDO9 on the other. After removing the BB CPU the shorts went away on both, so I reballed and placed it back and shorts came back. Thinking I just made a mistake, I reballed both again and shorts came back a second time. I then checked those lines on the BB CPU and sure enough they are shorted within the BB CPU itself.
1. Has anyone else experienced this ...
2. I have NAND Programmer(s) but nothing for BB CPU... Is it even possible? Or does anyone have a programmer to reprogram new IC's?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Now i have this problem... I re assembled phone
完成的
添加一条评论
3个答案
已选择的解决方案
You might want to reach out to specialized vendors like VIPProgrammer or UnionRepair. They may be able to program a replacement BB if you give them the proper metadata. I have a similar issue with an iPhone 6 where I may need to replace the BB.
I also seem to recall a similar post on the FB group (MicroSoldering & Board Level Diagnosis), you may want to check it out.
这个答案有帮助吗?
得分 3
3条评论:
@refectio I just received an answer from Vipprogrammer.com. I added a screen shot in my question...I was told that there is no programmer :(
完成的
Darn...
完成的
I have same problem here.. I re assembled phone :- )
完成的
添加一条评论
Yes, we've seen three of these now. There are two different versions of the iphone 7 logic boards. It seems to be only happening on one version. The short is within the BB CPU chip itself. No way of fixing it that I know of. Perhaps data recovery, but I'm not certain at this point.
这个答案有帮助吗?
得分 1
添加一条评论
I have seen lot of this case. Especially it shorted on BBPMU_TO_PMU_AMUX1 , PP_1V0_SMPS5, PP_1V0_LDO9. Theres no way to fix if u not found any caps shorted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
The Microsoldering Shop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 3,512
