跳转到主内容
加入维修社区 - 创建账户
MacBook won't turn on After replacing Thermal Paste.
Hi there,
My MacBook Pro Retina 13 inch Late 2013 won't turn on after I changed the thermal paste. I cleaned the CPU with Articleaner, the thermal paste is arctic silver 5. While cleaning, a little bit of the thermal grease and cleaner got around the cpu and motherboard. No cables or any additional hardware has been removed or changed, the CPU has been treated carefully while reapplying and cleaning the thermal paste. The black cover/plastic around the cpu dye was peeling off while cleaning carefully however. The MagSafe Connector gives a green light, which is for me personally an indication that their shouldn’t be any shortage or damage, right? I can’t perform any kind of reset, no smc reset or anything else.
I am so far clueless and don’t know what I can do in order to make the device work again, I hope you guys could help me out with this troubleshoot.
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I did plug in everything appropriately but it still doesn’t work....
完成的
添加一条评论
4个答案
已选择的解决方案
Try unplugging the magsafe adapter and the battery. Now press and hold the power button for 10 seconds. Next reconnect the battery then the mag-safe and see if you get a spontaneous reboot. Observe the progress bar and please report any anomalies.
UPDATE
If this fails I don't have a clue. You might do best to contact Apple and request a "flat rate repair" Total cost in Texas with shipping a tax runs $357 and takes a total for four days. Apple with have a FEDEX shipping box at your door the next morning. They will fix any and all failures for that fee it it has not received liquid damage or impact damage. Call 1-800-MYAPPLE, get to an agent and request it. You will need the serial number and a credit card.
这个答案有帮助吗?
得分 1
3条评论:
Just tried your solution and unfortunately it still doesn’t turn on, nothing happens and the green light from the Mag-Safe still turns on...
完成的
That’s really unfortunate... but still thank you both for your help!
完成的
Hey there! I had a similar problem after repasting mine, however I found it started when I plugged in my charger - turns out the keyboard wasn't plugged in properly, so the power button didn't work!
完成的
添加一条评论
Did you remember to plug the battery back in? I always forget that, also thermal paste is non-conductive.
这个答案有帮助吗?
得分 0
6条评论:
完成的
what was the reason you re-applied thermal paste? was it working before?
完成的
It was working, the cpu was getting really hot and I thought that reapplying the thermal paste after around 4 years would be a good idea....
完成的
@mayer may be more knowledgeable on this topic than me He'll be here soon.
完成的
Thanks in advance!
完成的
显示更多的1条评论
添加一条评论
So, did you fix it? I am with the same problem here.
这个答案有帮助吗?
得分 0
添加一条评论
I had a similar problem, I had reattached a cable in reverse!
这个答案有帮助吗?
得分 0
1条评论:
What cable? Currently have this problem
完成的
添加一条评论
添加你的答案
Fer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 3,479
