跳转到主内容
Repair guides and support for top and front loading Whirlpool brand washers.
Spontaneous lid lock light solid not flashing
After my washing machine has completed the cycle and the only light left on is the green light after the load has sat for a while suddenly the red lid lock light will come on. The light is not flashing it is solid. I will go to lift the lid and it will be locked I’ll put it back down lift it again and it comes unlocked and the light goes out. This is a sudden issue and it does not do it for every load. What could be the issue and remedy? Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off. If that does not do it, try putting the machine into diagnostic mode. The washer must be empty and the control must be in the OFFstate before pressing the touch-pad sequence to start the test.
这个答案有帮助吗?
得分 2
添加一条评论
I would like to add to this question. After a brief period, the lid locks when the washer is empty. I have to unplug it for a minute before it will unlock. Any idea why? I don’t know how to put it in “diagnostic mode.”
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hether 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 4,333
