跳转到主内容
Software for transferring data between replacing hard drives
I am going to put in a new hard drive but i do not know how to get the info for my old hard drive to the new one. I thought i might have seen it on the sight but now i cant seem to find it. When i transfer the data will all my downloaded applications go with it thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You'll need a external hard drive adapter or enclosure to hook the new drive up to and format it, then use SuperDuper to clone it>http://www.shirt-pocket.com/SuperDuper/S...
这个答案有帮助吗?
得分 2
2条评论:
when you say a external hard drive adapter, a external hard drive? and then copy the current drive in my computer to the the external one using SuperDuper then instal the new hard drive and the sync superduper?
完成的
You have to have a way to talk to the new hard drive and at the same time use the current drive. This can be done by using a adapter such as this one: http://eshop.macsales.com/item/Newer%20T...
or an external enclosure to put the new drive in, such as this one: http://www.ifixit.com/Apple-Parts/FireWi...
If you use a firewire drive you can also boot from it.
完成的
添加一条评论
添加你的答案
eweirick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,070
