跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
How or what can I do to save my phone from being completely dead
I to am haveing trouble i have got water on it several times but only drops its worked even after that but recently when i started it the apple logo flashed on and off and then my power button stopped working it wasnt a jam it just stoped working and in school when i needed it for a calculater my phone showed no sign of life i pressed all the buttons charged it everything what should i do or is there anything i can do
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Open the Sim tray and inspect the inside. What you're looking for is a bright red mark, you can't miss it.
There is a chance the indicator may not exist, but what it tells you is that water was present inside the unit.
Open the unit to inspect for water damage. Teardown Guide
Notes on how to clean water damaged components
Follow the guides, the screws are critical and the result can be more devastating if placed in the wrong location.
If you don't have the proper tools to complete this task, seek a repair shop in your area.
If the damage isn't from internal water damage what happened/what were you doing before the unit started acting up?
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ONYX 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 68
