跳转到主内容
Repair information for the Samsung Galaxy Tab 12.2, released in 2014. Model numbers: SM-T900, SM-T905.
32 个问题 查看全部
How to remove motherboard Anfang fix battery connector
I had the same problem as many others with the flickering, rebooting, not charging of the galaxy note pro 12.2 wifi. So I opened the back cover of the tablet and found the battery connector sitting in place but loose. When I touched it a bit too hard it moved and when I tried to push it back it fell apart. Now I have to replace it completely but can find No information on removing the motherboard. I did find a really good video on your website for the 10.1 I believe but my motherboard has a couple of more cable ribbons attached and I am not sure how to remove them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Here is a guide on replacing the battery if that helps.
Here
这个答案有帮助吗?
得分 1
1条评论:
Thanks but I am looking to replace the battery connector and have to remove the motherboard from the tablet to fix it.
完成的
添加一条评论
添加你的答案
Wayne De Groot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 736
