跳转到主内容
加入维修社区 - 创建账户
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Cannot find diagnostic LEDs.
I am working on a system for a friend. They have had this system for some time. They went to turn it on a few months ago and it would not power on. No fans not even a screen flicker.
I have tied all options to troubleshoot all accept looking at Diagnostic LEDs which I have not been able to locate. The only Apple tech Manual I could find is for iMac (27-inch, Mid 2010). I could not find one for Mid 2011.
Looking at the manual and following the location guide I have not been able to find the LEDs I have looked at logic board, while mounted, and cannot see them through the vents. When I plug in the power cord, which I have checked and has correct voltage coming to system, I can not see any green lights. This could indicate the PSU is bad, but would like to know if Diagnostics LEDs are in the same location as iMac (27-inch, Mid 2010).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The diagnostic LEDs are smack in the middle of the logic board.
这个答案有帮助吗?
得分 2
1条评论:
Thank you, and so you are right. Plug in power and nothing sitting up, that is why I did not see them initially. Ordered power supply and then will continue troubleshooting from there if need be.
完成的
添加一条评论
添加你的答案
kgsherman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 471
