跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
Change HD to SSD and upgrade RAM
Hello,
I have HP x360 13-s102TU touchscreen laptop. Currently it has 1TB hdd and 4 GB RAM. I wanted to check whether it is feasible to change the HDD to SSD and upgrade the RAM to 8 GB.
I was checking over internet, but havent found any substantial support in this regards.
Else, the only option remaining is to open the laptop and check.
Hoping for a solution on this.
Regards,
Rohan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your system specs: HP Pavilion x360 - 13-s102tu
完成的
添加一条评论
1个答案
已选择的解决方案
Max RAM 8 GB 1x1 PC3 12800
Looks like you are good to go for under $200
这个答案有帮助吗?
得分 3
4条评论:
Thank you @j0vian for the quick help. Can you tell me whether there will be a remarkable improvement in the system performance after this change in terms of using lightroom and photoshop?
完成的
There should indeed be a remarkable improvement.
完成的
Considering OP has a 5400 rpm HDD an SSD should be an extreme improvement.
完成的
@rohankonge If satisfied with the answer please choose the answer as the chosen solution so the problem will be marked solved. Thanks
完成的
添加一条评论
添加你的答案
Rohandeep Konge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 737
