跳转到主内容
Repair information for the Nextbook Ares 10A. Released in December of 2016. Model number: NX16A10132S.
50 个问题 查看全部
Why isn’t my tablet allowing me to run any apps?
I bought my tablet not even a month ago and every time I go to use it, it always says the app I’m on isn’t responding and it freezes a lot there isn’t one time it doesn’t? What can I do to stop that? I’ve never had a problem out of a nextbook doing that till I got the ares 10a!?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
My tablet is not letting me in to any of my apps. But they will let me in just one app, I can’t even get on the network either and I want to know what can you do.
完成的
my tablet will run ok on the internet but the 2 games and 2 tv chanels i downloaded won’t run! i’m either going to brake a finger or the screen touching it so hard! please help
完成的
Hi,
Did you check that the Android version in the tablet meets the requirements of the apps?
完成的
I have done all those things and held down power, volume down, and home button to factory reset I only have 2 games downloaded now and it still runs super slow wont run my games half the time and when it does they are so slow it's not even worth it.
完成的
添加一条评论
1个答案
最有帮助的答案
Alot of these tablets ship after they have been setting a while and the software gets a little out dated before it is sold. Sometime updating the software to the latest version can help. If that dosen't do the trick you may have to reset it back to factory settings.
Update (01/05/2018)
Reset
Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.
这个答案有帮助吗?
得分 2
2条评论:
Also dont forget to back up your data..
完成的
Where can you get fresh updates? I went thru the settings to update but it says its up to date. Is there a suit¿
完成的
添加一条评论
添加你的答案
ashley_ 17 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 2,021
