跳转到主内容
加入维修社区 - 创建账户
Model A1046 or A1095 / 1280x854 screen resolution
Upgrading RAM, what's compatible?
I thought I'd researched this enough, but I guess not. I'm trying to bring my old laptop up to speed. Currently had 2x 256Mb PC2700 DDR333MHz 200-pin SO-DIMM chips.
I'm trying to add 2Gb. Found a chip that's 1Gb PC3200 DDR400MHz 200-pin SO-DIMM.
I know there was one bit that was ok to go higher on without causing problems, thinking it was the PC3200 and not the 400MHz.
Can someone tell me which parts I have to match exactly and then which would be ok to stray from so that it would be compatible with this??
I know 2GB (2x1GB) is the Maximum RAM I can have, but is there a Max PC or MHz??
Please Help! And Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
We have to know EXACTLY which machine you have, some of the G4 PowerBooks used DDR and some DDR2. Please give the last three letters of your serial number. Thanks
完成的
DDR, it had DDR in it, and as far as I know, you can't put a DDR2 into a slot that originally had DDR.
完成的
Look in the battery compartment for your serial number please
完成的
添加一条评论
1个答案
已选择的解决方案
All 15in PowerBook G4 Aluminum models use DDR except only the very last 15in model which was the 1.67GHz PowerPC 7447a uses DDR2. Your PowerBook takes PC2700 RAM modules and for best compatibility use only PC2700. The maximum is 2GB.
Just to make sure and be on the safe side go to the following link, find your model and read the specs page. Towards the bottom you will see the RAM specifications: http://www.everymac.com/systems/apple/po...
I hope this helps, good luck!!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brownbailey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,054
