跳转到主内容
加入维修社区 - 创建账户
LG G Pad 8.3 是由 LG Electronics Inc. 开发的平板电脑,重 11 盎司(约 312 克),拥有 16 GB 存储空间和 8.3 英寸屏幕。
Why won't it shut off?
My g pad is frozen on the secure start up screen. I put in my pattern and it said to shut off and restart to unlock device. But now its frozen. And wont shut down for a hard reset. What do I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi,
Have you tried holding the power button until it force shuts down?
由完成的
Good morning! And to answer your question, I have held the Power button down for several minutes to no avail.
由完成的
Thank you for the info. I already done that. I believe that the power button is not working. When I got it apart it looked like it had been poked by something very pointed. I believe it either severed or disconected some wires in the ribbon. I would try to jump start it off the board, but can't find the "ground" and don't want to fry it. I can get a new starter/volume button for about 6 bucks.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
If the tablet is still on, then here is the ifixit LG G Pad 8.3 电池更换 guide.
Use the guide to disconnect the battery from the systemboard in the tablet. Once it has turned off, reconnect the battery and start again.
Alternatively wait until the battery has discharged enough for the tablet to shut down then fully recharge the battery before attempting to turn the tablet on again.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
william armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 1,537
