puedo instalar windows 10 en samsung chromebook XE500C13-K03US?
Si, se puede.
Yes, it can be done.
Mira aqui.
Watch this Video.
这个答案有帮助吗?
no he podido instalar windows 10 en mi samsung chromebook XE500C13-K03US?, como puedo hacerlo.
I dont know but take a look at its specs and you will find they are short for having Windows 10 running. Specially that one about disk storage (16 GB). https://gadgets.ndtv.com/samsung-chromeb...
这个答案有帮助吗?
What is needed to be done before installing window on Samsung chrome book
这个答案有帮助吗?
If you have an arm processor you cannot. If you don't you must first enter developer mode as in this video then you can install windows from a bootable usb stick, if your system meets the minimum requirements. Windows 10 for example can be installed as in this video.
greetings install windows 10 in a samsung xe310xba and I have problems with the sound card of the rest everything is fine if you can help me I would appreciate it
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 35
总计 9,188
2条评论
que se necesita para instalar windows 10 en mi chromebook samsung xe500c13
由 bob 完成的
me puedenenviar un manual de instalacion y los pasos a seguir para instalar windows 10 en mi chromebook samsung. gracias
由 bob 完成的
