跳转到主内容
Lightweight fleece jackets maximize core warmth without weighting you down. They wick away moisture and dry quickly to handle the most grueling of outdoor pursuits.
How do I get my fleece to stop shedding?
My fleece has been washed a few times but still sheds little (pink) bits on everything. I wore it under a different coat and found pink fleece bits all over the other coat. At first I thought it would just stop after washing but sadly it didn't. If anyone has any insight I would be so grateful! Thanks! -kate
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
已选择的解决方案
Hello Kate,
Patagonia created this iFixit guide detailing specific at-home laundering instructions to reduce fleece shedding.
Hoping this helps out!
Best,
Zach
这个答案有帮助吗?
得分 4
添加一条评论
Hi Kate,
You might not be able to stop your fleece from shedding completely, but you can definitely reduce the amount it sheds. Here are a few tips:
1) Use a lint roller.
2) Carefully and slowly use a shaving razor to remove any loose bits.
3) As soon as you notice pilling on your fleece, use this guide to tame any fleece buildup and prevent further shedding.
Hope this helps!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
kate 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 96
过去 30 天: 467
总计 44,656
