跳转到主内容
How to Remove Pilling from a Patagonia Sweater
你所需要的
  1. How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 步骤 1 中的图像 1,3 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 步骤 1 中的图像 2,3 How to Remove Pilling from a Patagonia Sweater, How to Remove Pilling from a Patagonia Sweater: 步骤 1 中的图像 3,3
    • Lay the sweater flat on a table. Identify the pilled area of the sweater. It will be covered in little balls of fuzz.
    • Grab your sweater stone.
    • If you ever forget how to remove piling, there is a handy diagram on the back of the box.
  2. How to Remove Pilling from a Patagonia Sweater: 步骤 2 中的图像 1,2 How to Remove Pilling from a Patagonia Sweater: 步骤 2 中的图像 2,2
    • Working along the grain of the sweater, gently brush the sweater with the sweater stone.
    • As you use the stone you may notice a funny smell, that is a natural part of the stone which is released as it crumbles away. You will also notice small pieces of debris, as the stone cuts away pills it also breaks apart slowly. Simply shake out the sweater when you are done to remove debris.
  3. How to Remove Pilling from a Patagonia Sweater: 步骤 3 中的图像 1,2 How to Remove Pilling from a Patagonia Sweater: 步骤 3 中的图像 2,2
    • Lift the sweater stone.
    • To prevent snags, always lift the sweater stone when changing directions.
    • Brush the sweater stone the opposite direction along the grain of the sweater.
  4. How to Remove Pilling from a Patagonia Sweater: 步骤 4 中的图像 1,2 How to Remove Pilling from a Patagonia Sweater: 步骤 4 中的图像 2,2
    • Continue brushing until the pilling is removed.
    • Clean your sweater stone by rubbing your hand across the stone to remove the lint.
终点
12等其他人完成本指南。
Brittany McCrigler
于03/05/12注册
88,250 声望
创作了132篇指南
团队
iFixit iFixit 的会员
Community
141 名成员
创作了17,757篇指南
4条评论
I also have used a disposable razor to shave pills and fuzz off of Patagonia sweaters and capilene - it worked really well. Just lightly run it down the sweater. If any fuzz is persistent, do the same but perpendicular to the first direction you used. It made my sweater and capilene pants look like new again!
AE3 - 回复
Yup, right there with AE3, disposable razor: they last a long time, and they can be re-sharpened a bit by shaving a piece of glass (nothing is disposable). This sweater stone looks kinda like pumice. I’m curious about it, but I wouldn’t buy one.
Rue Koegel - 回复
Can you use a sweater stone on the Nano-Air to remove piling as well?
Trey - 回复
Can't speak to fleece or nano puffs, but with wool sweaters a stone or plucking the pills pulls fibers upward and perpetuates the problem. Best to take scissors and ever-so-carefully, holding them parallel to garment, shear the pills off.
Susan McGrath - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 71
过去 30 天: 317
总计 59,378
