跳转到主内容
加入维修社区 - 创建账户
2016 年 2 月 16 日发布的蓝色、红色或白色 11 英寸 Dell Inspiron 11-3162。
Why won't windows install
It says windows installation cannot proceed
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Is that all it says? no error code or anything? What type of installation media are you trying to use? disk? Flash Drive? Or OS reset?
由完成的 分享
添加一条评论
1个答案
I will suggest you to check the BIOS settings provided below to see if you have similar settings. If not you may try these settings and then install the operating system.
  • Go to the BIOS screen by pressing F2 at the Dell logo 4-5 times.
  • Navigate to ‘Advanced Tab’ and select ‘Onboard Device Configuration’.
  • Set ‘SATA Mode’ to ‘AHCI’.
  • Navigate to ‘Boot’ tab and set ‘Secure Boot’ to ‘Enable’ and ‘Load Legacy OPROM’ to ‘Disable’.
  • Boot Mode should be set to ‘UEFI’.
  • Save the settings and Exit from the BIOS.
Once the system restarts, Go to the ‘One Time Boot Menu’ by pressing F12 at the Dell logo 6-7 times.
Select the boot device under UEFI to boot.
In case you have other problems in installing Windows update, check out those methods.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan groulx 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 37
总计 2,088
