跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Connected to wifi, but says "No internet connection"
As you can see from the title, I'm having trouble with an Iphone 6's WiFi connection. It detects all my networks but when I connect to it it says "no internet connection". I tried resetting the network settings, forgetting the network and even resetting my router. The networks wok with all of my other devices. I've also replaced the antennas inside the phone itself. I'm a tech at a repair shop and thankfully have a lot of parts laying around. Could it be a board issue or am I overlooking something?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
What iOS version are you run on? Maybe try updating its software.
这个答案有帮助吗?
得分 0
8条评论:
it's on the most current update, 11.2.1
完成的
Ok. I’m running iOS 11.2.5 beta on an iPhone SE. maybe try getting it checked at the Apple store.
完成的
Have you tried connecting to a different WiFi network?
完成的
I have not, there aren't any other networks near me.
完成的
You can go to a cafe or library for free WiFi. I’m not sure where you are but if you can find any free WiFi or use your friends WiFi to check.
完成的
显示更多的3条评论
添加一条评论
This could be the indicative of a failed board. Though replacing the board should be your last option, I believe it’s one of your only solutions. iPhone 6拆解
Take note that the following link IS A TEARDOWN.
这个答案有帮助吗?
得分 0
添加一条评论
I don't believe this to be a hardware related issue. Its quite possible that that the device is blocked and stuck in that state with no clear method to unblock it. So I was able to fix this issue by doing two things. (reset network settings on mobile device and network settings on WiFi network).
1: Reset network settings on my iPhone Settings > General > Reset > Reset network settings
2: Reset my router/modem combination to factor settings and then reprogram/reconfigure to my old settings.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Desselle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 18,895
