跳转到主内容
加入维修社区 - 创建账户
The second generation Integra was introduced in April 1989 and in this generation, one of the first VTEC engines ever manufactured by Honda was installed in a JDM Integra DA series.
My horn don't work
how do i fix my horn?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
traceymckellip start off by applying 12V directly to the horn. Watch the connectors and - goes on ground so anywhere on the horn mount will be fine. If your Horn sounds you know it is good. Then check all of your fuses (we need the proper year to help you out with that) to make sure it is good. Last you can check the horn relay which is located on right hand side on top of the fuses box.
You can also check on the relay if your switch is working. You'll need a simple multimeter for that. Let us know if you have the tools to do so in case you need further help with that.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
traceymckellip 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 1,098
