跳转到主内容
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
System won't boot after video card replacement
Replaced the GPU in my 24" iMac, following a number of web resources. No the machine won't boot. The pilot lamp (lower right corner) comes on, and at least one of the fans runs, but no screen backlight and (apparently) no HDD action. With the bezel removed, I have one green LED just above the memory slots, so I believe the Power Supply is OK. I've had the bloomin' thing open half a dozen times, looking for something I forgot to reconnect, but there don't appear to be any empty connectors. Any suggestions on what to do next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
After reading through a bunch of questions & answers here, I tried the CMD+OPT+Q+R startup and, lo and behold, I got a chime, backlight, and the system looked like it was starting to boot. Went through the grey screen, to the blue one, then... blank again. Do these new symptoms point anywhere?
完成的
添加一条评论
1个答案
已选择的解决方案
Put the old chip back in.
这个答案有帮助吗?
得分 2
9条评论:
Swapped the original GPU back in, and things are different. Not sure they're better, but different. The system starts now, get the chime, backlight, grey screen, blue screen and a few seconds of wallpaper, then back to a blue screen, with a spinner. Optical drive won't accept a DVD, and it seems like there's no OS to be found. Too late tonight to do more, so I'll sleep on it.
完成的
First zap the PRAM, start up holding down the option, command P & R keys, hold for three tones then proceed to start.
Your machine cannot find an operating system. Boot up from your system installation disk, insert the disk and start up holding down the "C" key, go to the second page pull down menu to Utilities -> Disk Utility and see if the drive can be repaired.
完成的
Zapped the PRAM, then tried to load the install disk. The optical drive still won't load the install DVD. Any way I can install the OS from my laptop DVD drive?
完成的
Yes in Target mode as long as the laptop has an Intel processor.
完成的
To boot in Target Mode connect the two macs via Firewire cable and start the sick mac holding down the "T" key. Then start the other mac normally. The sick macs hard drive icon should show up on the desktop. I'd run Disk Utilities first then start the new mac from your system installation disk holding down the"C" key and install a system on the other mac.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Don H Kemp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,744
