跳转到主内容
苹果订单编号为MC007LL/A / 27" 2560x1440 分辨率的显示器。
78 个问题 查看全部
Cinema Display Shows Block of Discolored Pixels
Hi,
I have a refurbished 27" Apple LED Cinema Display that I bought from Apple in 2014. It was perfect until yesterday when it randomly showed a vertical block of pixels near the middle of the screen with some form of discoloration. I made sure the graphic card is not the suspect here by trying another display as well as using the same display on a different Mac. The problem persists, so it's something in the display.
What surprises me is the fact that these are not dead pixels; they are dynamically changing color, and can clearly be seen kind of flashing. Also, this morning I woke up my Mac to find that the display went back to behaving normally.
However, a few hours later, it started doing the same thing, with different colors. Sound is working fine.
What is the cause of the problem? And is it worth fixing?
I also attached pictures of the problem when it happened the first time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
It looks like a damaged cable in the LCD, so switching the LCD would probably fix it. unfortunately those are pretty expensive, so it is probably not worth it, unless you can buy a broken LED cinema display that has a good lcd.
这个答案有帮助吗?
得分 0
2条评论:
Hi Rick, thanks for your reply!
I found a few displays with a missing case on eBay, and they sell around $100-300. It looks like they have working LCD panels. But I am inexperienced in this and I don't know exactly what to look for.
Do you have any recommendations? I mean, are there any keywords you suggest I use when searching for the part I need?
完成的
@archusain
@archusain do a search by the label on the back of your panel. that way you know that you will get an identical panel as needed for your monitor
完成的
添加一条评论
添加你的答案
Sayed Husain Almousawi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 260
