跳转到主内容
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
143 个问题 查看全部
Why won't my Fujitsu HDD 8.4 GB IDE not fully format?
Fujitsu HDD 8.4 GB IDE formats normally to 89% but hangs there.Whether format tried within MS Diskmanagement or from a floppy boot disk with Format.com,hangs at same spot.Disk Mgmt shows full 8.4 GB.
Is this disk recoverable ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Have you tried something like fdisk to delete the partitions that are active and then tried to format it? There is some low level formatting software out http://hddguru.com/software/2006.04.12-H... Now if you are an old DOS person you could even try to use Debug for this :-)and Microsofteven has it now on their site
1. Start DEBUG by typing the following at the command prompt:
debug
2. At the DEBUG hyphen (-) prompt, type one of the following commands:
G=C800:5
G=CA00:5
G=CC00:5
G=CE00:5
The above commands execute instructions starting at either location C800:0005, CA00:0005, CC00:0005, or CE00:0005, depending on which address is selected. If the computer freezes with the first address listed above, try the second address.
The program in the controller's ROM will execute and will query for interleave factor and other parameters. Answer these as appropriate; the hard disk will then be low-level formatted.
Give it a try and see what happens. BTW what OS are you using and what computer are we talking about?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maxim Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 453
