跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
How do I downgrade back to IOS 10 from IOS 11.2.1
how do i install an unsigned firmware (IOS 10) to my iphone 6S running on IOS 11.2.1
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Since you are already so far in IOS 11, the only way to downgrade would be to jailbreak. Which potentially, could risk you to mess up your software to the point where your phone is unusable.
完成的
添加一条评论
4个答案
已选择的解决方案
Unfortunately, it is no longer possible to downgrade your iOS to version 10.X as Apple is only signing the 11.2.X version at this time unless you had previously saved your SHSH2 Blob (see this article on GadgetHacks).
这个答案有帮助吗?
得分 2
添加一条评论
You can't. Only signed firmwares can be done on this phone.
这个答案有帮助吗?
得分 1
添加一条评论
While update firmware the modem firmware also upgraded so, downgrade is not possible on.
这个答案有帮助吗?
得分 1
添加一条评论
Apple has already turned off servers that digitally signed iOS 10 to allow for installation. Without this signature it is impossible to install iOS 10. If you used tiny umbrella to save those already signed signatures, you would still be able to downgrade to iOS 9 because the way the iOS signing occurred differently.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
moha98med 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 6,660
