跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
I can replace the touchscreen on iPad 2017(A1823)?
I crashed the touchscreen on the ipad 2017, can I replace it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sure you can. You can find the replacement parts here and some video repair guides here.
Replace a screen compatible with iPad 5 A1822 A1823 and iPad Air (1st Gen) A1474 and A1475. Includes all of the small parts preinstalled in the assembly. Part #821-4894-A.图片
产品
iPad 5 Screen Digitizer
$44.99
这个答案有帮助吗?
得分 2
3条评论:
Guides only for the wifi version, for LTE same thing?
完成的
There pretty similar. The main difference is that there are more antennas around the perimeter so you have to be careful when you separate the digitizer from the housing. You ay want to check the iPad 4 LTE guide for reference.
完成的
Thanks for the answer.
完成的
添加一条评论
添加你的答案
Максим Иванцов 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,385
