跳转到主内容
Identify correct power supply?
I want to purchase a new power supply which is identified as part # 661-3289 when I do the "ID your Mac" . The techie that diagnosed the problem said to make sure I order part # 661-3350. Will I be safe with the first one ? I don't want to return due to an ordering error.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Your machine has ALS
661-3289 was replaced by 661-3625
Any of these will work with your model: 614-0366, 614-0326, 614-0398, 614-0353, 614-0296
These parts have ALS (Ambient Light Sensor), if you don't need ALS you can order this part and remove the ALS from this Power Supply. If this part is not in stock you can order part number 661-3350 with-out ALS and replace it with your old ALS before installing.
Compatibility
iMac G5 (20-inch), iMac G5 ALS (20-inch)
So check prices.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Larry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,407
