跳转到主内容
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
99 个问题 查看全部
Can 16gb internal storage be upgraded to 32gb?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
已选择的解决方案
@Danj is right as far as the internal storage is concerned but this tablet can have its storage capacity increased with an sd card . Up to 128gb, one of the advantages of a samsung is its storage . Hope this helps
这个答案有帮助吗?
得分 5
7条评论:
Unfortunately, Samsung disabled the Android 6 "Format SD Card as Storage" which would combine on device and SD Card memory into a single storage volume. Having an SD card will only allow the device to store some apps that support it, music, videos, and docs on the SD card.
完成的
@avanteguarde this is the tablet not the samsung 6s and it does have a sd slot as well the samsung 6s comes with at least 32gb of space and up to 128gb and it can still do extra storage with micro usb connector . the phone will actually read a jump stick and there are cases the that will add battery and storage . Heres an example https://www.youtube.com/watch?v=c67nuA3v... the storage can hold all your largest space hogs in pics and music so its well worth it
BTW Merry Christmas to you and your Family SW
完成的
Hi @jimfixer ,
Would be interested in your thoughts on this one Why does my 2002 Trailblazer stall when accelerating?|
Cheers and a Merry Christmas to you and yours.
and to you @avanteguarde Merry Christmas
完成的
@jayeff took a look and posted a thought .Thanks for the heads up . Merry Christmas to you and your family. Hope you have a great day . As a kid I used to be jealous of folks like you who got to celebrate so much sooner then the rest of us ;-)
完成的
@jayeff Merry Christmas to you too!
Cheers!
完成的
显示更多的2条评论
添加一条评论
最有帮助的答案
Sorry no, the RAM is soldered to the logic board. Your only choice would be to swap out the logic board which is not really economical. Better to buy a new unit and sell your old one.
这个答案有帮助吗?
得分 5
添加一条评论
Yes im sure my answer in your question
Update (07/20/2018)
Yes im sure in my answer in your questions
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert J Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 49
总计 4,901
