跳转到主内容
Messed up colors on external display
When I connect my MBP through a minidisplay to vga adapter to my external vizio 26" monitor the colors become messed up. Black is green or blue and there is general static on the scree. How do I fix this?!?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Can you provide the model number of the Vizio?
完成的
corrected spelling on title of question.
完成的
Well done David, as long as you didn't remove the u from colour
完成的
添加一条评论
4个答案
已选择的解决方案
Yesterday, I went to the apple store and bought a mini display to VGA adapter and now it works great. So, I think that it was the adapter but thanks for all the help I really appreciate it!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I find this happens when the plug isn't properly secured sometimes. But I am sure you have already tried that by now....
Try another monitor if you can and see if you get the same thing.
If you see this happening on other monitors, then you want to figure out if it's the adapter or the actual mini-display port on your computer.
If you have access to another VGA > mini DP adapter, then absolutely check to see if you can cancel out the adapter as the problem.
Component isolation is your first step. good luck!
这个答案有帮助吗?
得分 2
2条评论:
yea thanks thats great advice I tried doing these things, but sadly I have a vga adapter and no other monitors take that input... thanks though!
完成的
Glad it was the adapter!
完成的
添加一条评论
Try the moniter reset button/Degaussing? Wiggle connections?
这个答案有帮助吗?
得分 0
添加一条评论
Make sure your monitor's settings are set to RGB and not something like YPBPR.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
grey 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 4,654
