跳转到主内容
问题已关闭
Can an old internal drive be used externally.
I want to swap out my old drive which is working but in trouble and be able to drag back into the new one only what I need from the old drive. If it was mounted in a case of some kind I could connect it and look at the contents. I have two backup drives that might work but the cases have no screws.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You most certainly can use old drives as externals. If you go to www.newegg.com you can buy an enclosure for your hard drive that will make it into an external drive. I've used one of these before and it worked great. You can get them for relatively cheap ($10+). If you can't find one on newegg that is cheap enough amazon.com has them as well. I think they're just called external enclosures. Hope that helps! Good luck!
这个答案有帮助吗?
得分 2
1条评论:
+ that's it. Lets reuse,reduce, recycle all that good stuff
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 594
