Can an old internal drive be used externally.
I want to swap out my old drive which is working but in trouble and be able to drag back into the new one only what I need from the old drive. If it was mounted in a case of some kind I could connect it and look at the contents. I have two backup drives that might work but the cases have no screws.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
You most certainly can use old drives as externals. If you go to www.newegg.com you can buy an enclosure for your hard drive that will make it into an external drive. I've used one of these before and it worked great. You can get them for relatively cheap ($10+). If you can't find one on newegg that is cheap enough amazon.com has them as well. I think they're just called external enclosures. Hope that helps! Good luck!
这个答案有帮助吗?
按维修分数 2
评论:
+ that's it. Lets reuse,reduce, recycle all that good stuff
添加一条评论
添加你的答案
Martin Cooper 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 585
