跳转到主内容
加入维修社区 - 创建账户
丰田于 2001 年 9 月发布了 2002-2006 年款的 Camry XV30 系列,将其作为一款体型更大的轿车。
battery light flickers and abs light came on for a short time
I was driving to work and my battery light kept flickering. Then on my way home from work it began to flicker again and my headlights kept going dim then my abs light came on but then all of a sudden both lights went out. My headlights went back to normal then the battery light kept flickering again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi @mel6589 ,
The car's alternator may be failing (more correctly the regulator within the alternator) or perhaps the fan belt may be slipping or loose causing the car's battery and electrics not to receive the correct amount of voltage.
If you have a DMM (Digital Multimeter) you can use its' Voltmeter function to measure the output of the alternator.
1. With the engine switched OFF, measure the voltage across the car's battery terminals. On a good battery it should read around the 12V DC mark.
2. Ensure that the car is either in Park (automatic transmission) or in Neutral (manual transmission), with the handbrake (emergency brake) applied and then turn the engine ON. Measure the voltage across the car battery terminals. It should be in the range 13.8V - 14.2V DC.
Be careful when you do this as the engine is running
If it is below the low reading then there is a problem with the alternator or belt.
If you don't have a DMM or access to one (do you know anyone who might have one?) then take your car to an auto electrician to have it checked out.
这个答案有帮助吗?
得分 1
1条评论:
If you are in the States, take it to your local auto parts store such as Sears. They will check your alternator and car battery for free.
完成的
添加一条评论
添加你的答案
mel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 12,989
